I’m using the default Shaded View setting for perspective, the only thing I’ve messed with is edge thickness and lighting scheme. When I pan around polysurfaces for some reason the edges from other polysurfaces bleed through. It makes it very hard to understand what I’m looking at. Is there a solution?
"command _TestZBiasFactor"
I’ve seen this one mentioned a few times now lately. @jeff doesn’t really want us to use this command, though it’s a long time ago that this was stated. @jeff, do you still want us to send in example files or are you working on something new?
The testbias command seemed to work this time, I also deleted some far away objects which probably helped. But for future reference, what do you mean by shrinking trimmed surfaces?
And does anyone know if I should be using this text command? Is it safe? It told me to report my use of it to McNeel.
i could explain it poorly or try looking up shrink trimmed surfaces in the help menu… you’ll learn a lot about rhino and how it works with control points and surfaces generally.
