when you have exploded surface, already meshed by the shaded view, then if you are going to joint the surfaces, Rhino is going to meshed that surface again. Is possible make Rhino avoid to mesh surface all the time like have it meshed only the single surface indiplendenty if the surfaces are joint or not?
Thank you
Mika
Nope. When you join the surfaces, Rhino has to create a new, single mesh that respects (matches across) the surface joins. So the original meshes are discarded.
–Mitch
Thank you Mitch for the replay.
That feature as an option will be so useful! I’m working with in huge files (500/1000 Mb) with a lot of surface to edit. When I can, I’m working with group feature, but in the end i always need to joint than I have to modify something it take so much long just to see what is going on in the shade view…
That want to be a suggestion for developer team.
