Downloaded Rhino 7 and continued working on my file with it. This morning, I opened my file and the program didn`t respond (which occurs pretty often since I installed rhino 7), so I closed it. When I opened it again, the shaded modus suddenly appeared a very dark grey and the program doesn’t run completely fluent anymore. I deinstalled rhino completely and redownloaded: it didn’t help. Also, I have this problem with every other Rhino file, too.
Please run the SystemInfo command in Rhino and copy/paste the results here.
Rhino 7 SR2 2021-1-21 (Rhino 7, 7.2.21021.07001, Git hash:master @ 96ff97351fbdf5d2acdeaf781aea1577f2ff60f7)
License type: Studentenlizenz, Build 2021-01-21
License details: Cloud Zoo
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 16Gb)
Primary display and OpenGL: Intel® UHD Graphics (Intel) Memory: 1GB, Driver date: 5-19-2020 (M-D-Y). OpenGL Ver: 1.1.0
Secondary graphics devices.
NVIDIA GeForce GTX 1650 Ti (NVidia) Memory: 4GB, Driver date: 9-23-2020 (M-D-Y).
> Integrated acclerated graphics device (shares primary device ports)
- This device is not being used
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
- Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Nicht unterstützt
Driver Date: 9-23-2020
Driver Version: 27.21.14.5241
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.2.21021.7001
Hmm, this appears to be the problem -
Maybe your video driver got corrupted - I think I would start by downloading the latest driver from NVidia and try installing that.
Hey!
First of all thank you for your help!
I am pretty much a beginner when it comes to Rhino, so I didn’t know how to find out what was wrong! When I sent the System Info to you, I read it closely and figuered I maybe have to run some updates. Did that and now everything works just fine!
Thank you again for this tip
