Shaded mode but with pecked lines for drilled holes etc?
V5
Is there a way in V5 of using shaded mode and having pecked lines for drilled holes etc as if an engineering drawing ?
Cheers
Steve
When you refer to pecked, I believe you mean the CNC process for a hole.
Can you create a centerline at each hole that will show up in shaded mode?
I am in layout view. creating a coloured plan set.
I have a side view of an object in shaded mode and a hole runs left to right through it but one wouldnt realise that without a pair of dashed lines (pecked lines) showing that.
front view of it one would see through a hole, inless the object had another part behind thus making the hole the same colour as the rest !
Steve
Unfortunately I can only think of a multi step approach to this that would create the dotted lines for the sidewalls of the holes and combine that with the shaded view.
draw them in , in layout view !
However if there was a need to see these outside of layout view, that wouldnt work.
Steve
