my shaded display even after restoring default settings in display options is showing the backedges, Any one know how to fix this? Thanks.
Hi Eric- try messing with the testZBiasFactor command- make it Less in this case I’d say.
Thanks Pascal, I found the problem it was a left over clipping plane (generated from the section tools menu) that was causing it (it was inactive but still causing the shaded display to malfunction). i deleted it and things are back to normal.
