When I right-click on “shade all viewports,” it doesn’t work..?
If I am in a viewport and left-click the shade viewport (marked C below), it works fine
If I am in a single view or 4 views and right-click shade ALL viewports (marked A below), they shade ok and in the command line it is waiting for some input, but when I hit Enter, the shading disappears?
This also happens when I left-click in a single viewport on the button marked A below
When I go into the menu and use Button B it all works ok but this is marked “Set viewport shaded”
I the button A meant to be a momentarly on button or is it not working right?
You guessed it right — that A button runs the Shade command, which is a temporary shade by design. It shades while the command waits at the Choose Shade settings prompt, then Enter, Esc or starting another command ends it and the viewports go back to their previous display mode. Same deal for the left-click on A, just one viewport.
B and C set the viewport display mode instead, thats the change that sticks. For all viewports in one go there’s a “Set all viewport displays to Shaded” button in the same flyout, or run SetDisplayMode with Viewport=All Mode=Shaded.
This is the same behavior in 8 and the 9 BETA. If a button is doing something different than i described you may be on a customized macro — right-click > edit the button and post the macro here, and let us know what version you’re running. Thanks!
