Hi @jeff,
when i am in a Shaded Viewport, and run the non permanent _Shade
command, there are various options to Show the grid, axes, curves, isocurves etc. The option to show/hide curves does not work here, it toggles the Z-Axis instead which has been a bug since early V5 days.
To repeat, run _Shade
and set it to _DisplayMode=Shaded
and _DrawCurves=Yes
. Press Enter to exit the non permanent _Shade
display. Create some curves in the document. Then Run _Shade
and set _DrawCurves=No
. In my case, the curves stay visible but a Z-Axis is shown. Once i use _Enter
and run _Shade
again, the curves are hidden as they should. If i set _DrawCurves=Yes
the Z-Axis gets hidden.
I do not understand why there is a Z-Axis involved at all. The viewport was in permanent Shaded Display mode and when i enabled _Shade
which it is set to _DisplayMode=Shaded
c.
