archz2
March 16, 2021, 2:59pm
#1
Severe heat up and lag while using Rhino
I am facing an issue of heat up and lag in Rhino.
This is happening with files that hardly have any geometry. Even if I create a new file with just one rectangular surface, my system heats up to 95 degrees celsius. I have to force close Rhino restart my laptop in order to get back to normal. After an hour or so, this happens again.
I have 3-4 folders open and just one notepad file with 3-4 sentences. No other software are running in the background. My laptop is on flight mode. My antivirus is disabled.
My system specs are
Intel core i7-8th gen processor-8750H, 2.20 GHz
230 GB SSD, Samsung EVO 970, nvme. Rhino is installed on this drive.
1 TB Hard drive
4GB Nvidia GeForce GTX 1050Ti graphics card
Check the video here. It’s a 56 mb file.
https://www.dropbox.com/s/6x126jmvcd8a7ud/VID_20210316_201300.mp4?dl=0
The flicker is happening automatically. I am not touching the laptop at all.
My windows are up to date, my drivers are up to date.
My Rhino version is 7.4.21067.13001.
Please run the Rhino SystemInfo command and post the results.
How many monitors are you running?
How are they connected?
What resolution?
Thanks
archz2
March 16, 2021, 4:14pm
#3
I don’t have any monitor attached. I am using my laptop. It has only one screen. The resolution is 1920x1080
Here’s the system info output. I removed the hash text.
Rhino 7 SR4 2021-3-8 (Rhino 7, 7.4.21067.13001, Git hash:master @ ------I removed this text)
License type: Corporate, build 2021-03-08
License details: Stand-Alone
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [88% battery remaining]
Primary display: Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 2-18-2021 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 Ti (NVidia) Memory: 4GB, Driver date: 2-23-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.72
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-23-2021
Driver Version: 27.21.14.6172
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino WIP\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Users\JUGGERNAUT_BOLTZ\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp “SpeckleRhino2” 2.0.5.0
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot10RhinoPlugin (ccedd9da-83b9-429a-aec5-8ec90b85fe67)\1.0.0.0\KeyShot10RhinoPlugin\Rhino 5.0\KeyShot10RhinoPlugin.rhp “KeyShot10RhinoPlugin” 1.0.0.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino WIP\Plug-ins\Commands.rhp “Commands” 7.4.21067.13001
C:\Program Files\Rhino WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.4.21067.13001
C:\Program Files\Rhino WIP\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.4.21067.13001
C:\Program Files\Rhino WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.12.17.906\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.4.21067.13001
C:\Program Files\Rhino WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino WIP\Plug-ins\Displacement.rhp “Displacement”
pascal
(Pascal Golay)
March 16, 2021, 4:18pm
#4
Hello - please disable all of these plug-ins:
Karamba
SpeckleRhino2
V-Ray for Rhino
in Options > Plug-ins page and then close and re-open Rhino - does that behave any differently?
archz2
March 16, 2021, 4:58pm
#5
I have disabled the following plugins
SpeckleRhino2
V-Ray for Rhino
I didn’t disable Karamba as it’s only a license check plugin. Moreover, I didn’t want to risk getting an error in Grasshopper launch as it is used within Grasshopper.
So far everything is normal. I’ll post back once I face an issue. Thanks for the tip!
