Not sure what this function should do exactly, but this looks like a bug in RealtimeDisplayMode
function
public virtual void SetUseDrawOpenGl(bool use);
We can override, but can not change the value of use (not a reference)
Márton
function
Márton
If you override SetUseDrawOpenGl you are supposed to always call the base class method.
You’d generally override this only if you need to keep track of calls to this function yourself, the actual magic that happens is as per documentation:
During run-time change whether to use OpenGL drawing of results or not. For instance offline rendering (viewcapture* with different resolution than viewport) could use RenderWindow instead of direct OpenGL drawing
If you pass true
to the base implementation the RDK realtime integration mechanism expects you to use OpenGL to do the drawing into the framebuffer. If you pass in false
you’ll be using the instance of a RenderWindow
in the StartRenderer
to use for collection your render result in. This instance will be used to draw the results to the viewport for you.
For Raytraced we use the RenderWindow
method when 1) we’re doing an offline/modal render (i.e. ViewCaptureToFile with different settings than viewport) 2) the graphics driver doesn’t support at least OpenGL 4.1 or 3) Rhino is run through RDP
In all other cases (that are pretty much the default) we use OpenGL to do the drawing of the Cycles results into the Raytraced viewport.
For Raytraced I am not overriding the SetUseDrawOpenGl(bool)
function, as I don’t need to keep track. But I do use it to switch between the OpenGL and non-OpenGL (RenderWindow) drawing mechanisms of the underlying realtime display integration mechanism of the RDK.
You can find three uses of the function in https://github.com/mcneel/RhinoCycles/blob/rhino-6.x/Viewport/RenderedViewport.cs
The very low-level OpenGL drawing I do inside the Cycles engine like so: https://github.com/mcneel/cycles/commit/3043b8c5ebcebb361c7d288481ba6e1cf17c0b84#diff-25d902c24283ab8cfbac54dfa101ad31
Thanks for the explanation.
Drawing with OpenGL could be a good way to go…
But what I don’t understand from your examples. How to connect to the opengl context? Can I get it from Rhino?
Márton
When you get the chance to draw your results into the framebuffer Rhino has already prepared OpenGL for you to draw in.
The process for a realtime display integration goes something like this:
Raytraced
initializes the Cycles engine here also, if neededPostConstruct()
on your implementation is called if you have an override for it. In Raytraced that is used for figuring out OpenGL supported level
StartRenderer
SignalRedraw()
.DrawOpenGl()
is made at which point you can use OpenGL to draw your results to the framebuffer, Raytraced
implementation looks like this. You see it calls into a function on my actual engine, and through several function indirections (because wrappers) you’ll find that the result is just really being drawn as a texture on a quad over here.In short: you don’t need to get a context, Rhino already has set it up for you. If you investigate the actual framebuffer drawing code in Cycles as used in Rhino you’ll find that there is no context fetching/switching/setup done anywhere. Drawing just happens.
Yes it seems it is working:) without manual opengl context handling. Nice! Thank you.
Márton
Good to hear
Do ask when you have more issues to solve!
