For V6 and later - within the same version : The easiest way is to simply copy the settings-Scheme_Default.xml file from one installation to the other, replacing the original. The file is located at C:\Users<username>\AppData\Roaming\McNeel\Rhinoceros<version number>\settings . This may also work when upgrading versions, but it is somewhat risky, as some settings change between versions.
