I want to set the working folder to the current document folder on startup, as I am constantly bouncing from project to project. I made a simple python script and called it on startup using a command script in Tools–>Options–>General, but it looks like that gets activated “too early” to work. So what’s the best way to do this, and to have it get set every time a document is opened instead of just on startup?
Hi @JimCarruthers,
have you tried to subscribe to scriptcontext.doc.EndOpenDocument
and put the code to setup the working folder in the event handler ? You might then set this script in the startup command list, eg. something like below:
import Rhino
import scriptcontext
import os
def MySetupWorkingFolderEvent(sender, e):
try:
if e.FileName:
folder, filename= os.path.split(e.FileName)
rs.WorkingFolder(folder)
except Exception as ex:
print ex
def RunCommand():
key = "MySetupWorkingFolderEvent"
if not scriptcontext.sticky.has_key(key):
scriptcontext.sticky[key] = MySetupWorkingFolderEvent
scriptcontext.doc.EndOpenDocument += MySetupWorkingFolderEvent
if __name__=="__main__":
RunCommand()
it might get problematic as it also sets the working folder when opening a new empty file (template).
_
c.
Well it took me close to 6 months to get around to testing this but it seems to work! Yeah I need to do something different when starting a new emptly file, I can probably handle that…
