Setting up the material at the object
To set up a material (+ instant update in practice) you need to select an object, and if I select it (isocurves are shown here), which can be a lot in general, how can I hide them?
How can you do something? :disappointed:
Yes…
https://mcneel.myjetbrains.com/youtrack/issue/RH-17045
Well, okay :expressionless:
I found some solution here … Objects with a certain material are located on a certain layer, the setting of Use Layer Material is set, in the layers click Material and edit in real time …
