So, after getting instant crashes with the latest WIP when trying to load my personalized workspace - which links to a .rui file converted over from V7 and which was linked before all this container junk was released - I decided to rename the existing containers.xml file and have Rhino re-create a new one - as suggested in another post.
That stopped the crashing, but of course, no miracles, it now opens with the default āworkspaceā - or whatever you are calling it these daysā¦ Window Layout? Library? Container set? I have no idea anymore.
So, I went back and via Options >Appearance > Toolbars and re-linked the .rui. (As an aside note, the placement of this function is bizarre, as everything else that concerns toolbars, containers etc. is now only available under the Window menu. Linking a .rui file is not an āappearanceā thing IMO.)
So, now I get my custom .rui PLUS the default. Formerly, one could just close the default.rui. Now, itās necessary to go to Containers - link not available through Options so you have to close that - and then find all the open containers/toolbars in the default ālibraryā and close them - because you canāt actually close the default library itself. But waitā¦
All of the toolbars - both the ones in default and the ones from my custom .rui are now all mixed together in the left hand pane of the containers panel. I have to figure out which ones are from default and which ones are custom - and the names might have been the same - looks like a ānewā was automatically added to my custom ones. Plus, itās not possible to close that mess of a left side āMainā toolbar - the box is unchecked, but itās still open. Itās necessary to physically drag it out of the LH docking and X to close it.
And man, it still looks UGLY with those .... bars and the thick bordersā¦
Iām having toolbar issues, too. In the latest build, I canāt dock a toolbar at the bottom next to the Osnaps, or above the osnaps. Seems I canāt put two toolbars along the bottom in any way.
And it took me a long long time to look under Appearance. But I suppose itās good to group all of the toolbar stuff in one place, and some toolbar settings are appearance-related, so whatever - Iād get used to it being there.
In Containers, you will find the containers that were made and that might or might not be opened at the time you open Containers. Containers are not part of a library, but can contain parts from different libraries. A library is then a collection of tools and toolbars. What might be confusing here, is that the containers you see, are named after the toolbars that ācreatedā them. But this is quite similar to how V7 generated a group with a single tab inside it, with the same name. The difference with V7 is that in V8 these groups can now contain either panels, toolbars or a combination of those, and that they can contain stuff from different libraries.
So as for this part:
What you see in the left hand side are not the toolbars themselves, but the containers that contain the toolbars, though the names can be the same.
Regarding the borders and dots, in latest WIP these changes have been made:
Borders are slimmed down
The gripper dots now only appear on containers that donāt have text in their gripper area
The gripper dots should now be aligned better and reduce in number when height or width forces them to
It seems to be working at the moment. Thereās a new problem, though.
In a previous WIP, Iād added a new toolbar to the standard tools at the top of the screen called Quick. I then dragged buttons to it to populate it, since there didnāt seem to be a way to add a toolbar any other way. Today, in the new WIP, those buttons are all grey circles with no commands. I know changes have been happening, so maybe thereās now a better way to add toolbars to the standard collection?
Hi Peter, do you recall which version that was?
Itās not the first time I see icons getting deleted, but that was before changes were made to how custom toolbars work.
Ok, so I just linked a file so that I could restore my buttons. I closed the toolbar that had the grey circles, and created a new toolbar with a new name. Then I dragged a copy of each of my buttons from the linked file onto the new toolbar. Half-way through, I closed and re-openned the file a few times and everything was going fine. I finished copying the buttons over, then I closed the linked file. Now the buttons that Iād dragged over to the new toolbar are grey and commands are gone. I guess I donāt understand the process of how to get a toolbar or a bunch of buttons from one toolbar or collection (or whatever the terminology is) to another.
Honestly, I would just use the linked toolbar instead of the āstandardā toolbar, but I donāt see a way to turn the āstandardā toolbar off. Actually, I see how to ācloseā the standard toolbar, but no idea where Iād go to restore it if I need it later.
Whenever the source toolbar is linked, the buttons show up just fine, so for now Iāve closed the linked toolbar (so itās still linked but invisible I guess) and the screen currently looks the way I want it to. But there was a lot of things that are still mysterious to me regarding toolbars in V8. Maybe itās because the toolbar that Iām linking was the āstandardā toolbar in V7 and maybe has same name as the standard V8 toolbar?
Actually, I take that back. Still seems I can only have one toolbar on the bottom of the screen. In Rhino 7, I could have multiples, either stacked or beside each other, as in the image below. Canāt get it to work in WIP.
As @inju mentioned, you need to drop it on the (small) blue rectangles that appear. These should be larger and is logged as RH-72559 Docking: make the target zones larger
