Hi all!
I’ve recently been creating Rhino files with a lot of different colors, and have been wanting to set up my default file template so that the print colors always default to “By Display.” Does anyone know of a way to do this?
(For a bit more context: I’m usually making graphics and things with a lot of colors in Rhino (example below) and I am editing and adding a lot of colors using a “SetColor” macro I set up. (! -Properties Pause Object Color Object Colorpicker) - this changes the display color but not the print color, so when I go to print my drawing, I often forget and have to go into the menu and set the print color to “By Display,” and then it works fine. But since I basically do this every time and rarely want the print color and display color to be different, I figure it’s probably better to automate this step. I’m open also to changing my macro, but I don’t see an easy way to change both Color and PrintColor at the same time)
Happy to hear any ideas. Thanks for your help ![]()
File sample below, just to show the amount of colors I’m working with
D Meets A Test.pdf (6.2 MB)
