Setting max radius in export dwg polycurves w/bulge arcs
hallo everyone,
who knows if or how you can limmit the max radius when you export a dwg out of rhino with the settings for polycurves in the edit scheme box: polylines w/bulge arcs.
Because my cnc machine can not handle with numbers bigger then 999999.999 (and that wil be for the radius).
ini file??? export settings???
thanks
edward
I do not think you can limit the radius one way or the other, but if you check “Simplify lines and arcs” and use a reasonable tolerance, it might convert these extremely large radius segments into lines on export.
–Mitch
