Setting / Editing Insertion Points on Custom Profiles
Hello there, is there a way to edit a custom profile to set the insertion point when placing the beam using VisualArq? I’ve created several profiles for cornices running along a roof edge, but when prompted the insertion point is in an awkward place along the profile line. I want to change that so the insertion point is on a corner in a logical place. Would I need to re-create the profile from scratch? How would I specify the control point or insertion point location? Many thanks as always.
Hi @christophercurtissmi It is not possible to set a base point for a custom profile when it is used for beam or columns. VisualARQ takes the bounding box of the custom profile to determine the object alignment (center, top right, top left, etc, ). In addition there is a X and Y Alignment Offset parameters you can use.
