Hi All
Is it possible to change UDA for bolts?
Beams post works fine cant get Bolts to work
Regards
Hi Darozas,
The attribute labels you see in the dialog are usually not the name that’s needed for setting and reading the attribute (reason being that the label can change between different environments, while the underlying name remains the same). In this case the underlying attribute name is BOLT_COMMENT.
One way to find out the name is to set a value for the attribute field manually in Tekla and then use the “Get All UDAs” component like this:
This FAQ might give a few helpful hints as well:
Cheers,
Sebastian
