If the viewport display mode is Rendered and SetObjectDisplayMode changes object display mode to Ghosted, and the object is a surface, polysurface, or mesh, the object disappears.
Hi Andrew - does this happen if he Ghosted mode is set to defaults?
No it does not. I could not figure out which setting is vanishing the ghosted objects, so I uploaded my options in the following files.options defaults.ini (117.8 KB)
options custom.ini (117.8 KB)
