I have a file with several dozen planes - simple rectangles. Surfaces if you will. Is there any way to select them all and make them all the same height relative to the c plane?
Thanks in advance.
Thanks in advance.
Hi arail,
Try the SetPT command and use only the Z
select them all and use setpt in the z (or whatever plane you are using)
then use 0,0,[your distance from cplane 0 here]
or
gumball scale to zero, then gumball transform in the z your desired amount. I like the gumball method myself-
Excellent.
Thanks
you can also use ProjectToCPlane or Align.
