Set user text doesn’t allow selecting multiple objects
Option Explicit
Sub SetUserText()
Dim sObj
sObj = Rhino.GetObjects("Select object to SetUserText",0, True, True)
If isNull(sObj) Then Exit Sub
Rhino.SetUserText sObj, "A", "0"
Rhino.SetUserText sObj, "B", "1"
End Sub
Thanks all
H John - if you get a list of objects you need to iterate the list
Sub Main()
	Dim arrObj
	arrObj = Rhino.GetObjects("Select object to SetUserText", 0, True, True)
	If isNull(arrObj) Then
		Exit Sub
	End If
	Dim arrkeys, i
	arrKeys = array("A", "B", "C")
	For i = 0 To uBound(arrObj)
		Rhino.SetUserText arrObj(i), arrKeys(i), i
	Next
End Sub
not working
Brep A : A,0 ; B,1
Brep B : A,0 : B,1
or
Brep A : A,CD ; B,EF
Brep B : A,CD : B,EF
Hello- - sorry, I have no idea what this means. If you want help from me, please explain the problem clearly, and post the code that is not working.
