How to set up texture map in that object? i wanna scale a pattern thats to big.
Untitled.3dm (8.9 MB)
Here is a link to an McNeel tutorial:
at around 9:08 it starts to cover uvw unwrapping, which is probably what you want to use
good luck
Andy
looking at the file I see that your current setup for the objects texture is surface (which is the default). If you just need a rough resemblance, you can also tinker with the repeat settings in the texture dialouge to get a decent result
Ah i see.. Thanks Walther!
