Set print display ON as default?
Can I set print display ON as the default? Would this be a global setting? Perhaps in my template for all layouts?
That would likely cause more problems than it would solve.
If you want it on, add the command to Options > General > Run these commands every time Rhino starts:
Please assign your posts to the Rhino category.
Thanks
