Set points replaced in mac version?
I was following a tutorial that used the set points command in the transform menu. It doesn’t seem to be there in the mac version. Is it elsewhere or is there a command that’ll do the same thing?
SetPt
(on a phone… not sure if it’s in a menu… can’t check right now)
I found it. I was trying to delete this post before it was too late, but I couldn’t figure out how. The set XYZ coordinates is the same command. It’s confusing sometimes as the name used can differ from the icons and drop downs
