Despite the fact that Alignment=World is set, you still need to enter the coordinates in world, otherwise they will be considered as CPlane coordinates. Looks like the Alignment argument is only for a single value…
value…
got you, thanks.
input as you suggested works fine here.
I posted because I am not sure if it worked differently before, as i remember to not have used “w” with setPT before. could be bad memory though
I don’t know either, it does seem buggy to me considering that there is a World/CPlane command switch that looks like it’s being ignored… I pretty much never use SetPt this way, so I can’t tell if something has changed or it’s always been this way…
The “Align” switch is used only for determining whether the selected axis for alignment are the world axis or view dependent. It is not used for coordinate input. Coordinate input is consistent with coordinate input for other commands - assume local unless preceded by the “w” for world input.
