When I use the set parameter component, it runs quickly. However, when I then disable the component it then seems to go through a long loading processes, like its re-executing the change in parameter.
Does anyone know why this is the case, it also happens if I do the same parameter change through a python API script, the change happens but then when I disable, it begins a reload process.
Thanks
