In Rhino PC version it is possible to set print output window in layout manually which make it possible for a layout to contain many drawings or a full scale drawing. In Mac version the set button doesnt show up in layout printer menu in layout (it does show up in model space). I have a faint memory that I have done this in MACrhino before. Is this option removed or moved?
Hej Fredrik -
Things are a bit different on macOS. Are you trying to create a PDF file? Which command are you using?
Hi Wim!
I just use print command but I can’t set output area manually in layout.
Hi Fredrik -
On macOS, that invokes Apple code that we can’t control. The recommended way to create a PDF file is to use the ExportAll
command and pick the PDF file format. You should then be able to manually set a part of the layout to be printed.
