Hey guys, is there a command to set the object display colour?
I can use the dropdown and change it that way, but want to know if there’s a command that I can put into a macro I’m writing.
Thanks!
Thanks!
hi Aaron,
you can use the _-Properties command (make sure to put “-” before for command-line version.) From there: Object > Color > Color Source=Object > and I guess it will take RGB values to set specific color via macro.
hth
–jarek
Perfect!
Thanks Jarek
