I would like to add a custom python command, I’m not quite familiar with the rhinosyntax though, and I am not too good in python either
So what I want to create is an alias which does this:
First, it checks if I have selected One Object. If yes, it should run the command SetLayerToObject. If not, it should Set the Layer named “0_Default”
If the Layer “0_Default” is not created yet, it should create this Layer and set it active.
import scriptcontext as sc
selectedObjs = rs.SelectedObjects(True, True)
if selectedObjs:
layer = sc.doc.Layers.FindName(rs.ObjectLayer(selectedObjs[0]))
sc.doc.Layers.SetCurrentLayerIndex(layer.Index,True)
else:
layer = sc.doc.Layers.FindName("0_Default")
if layer:
else:
rs.AddLayer("0_Default")
since you didn’t specify, I assumed multiple object selected is possible and therefor you might aswell have objects on different layers selected, so I took the layer of the first object.
