Set layer print color to layor color
When I set the print color of a layer, and later I changed my mind and want the print color to FOLLOW the layer color, how can I go about and do that? I am able to manually set the print color the same with layer color, but it won’t change automatically when I change the layer color again.
Thanks!
Hi Vincent - right-click on the print color swatch and choose ‘Reset print color’ from the menu.
WOW! That is very difficult for me to find it by myself. Good to know, thank you very much!
I agree it’s not very easy to find - I had to hunt a bit myself, and I’m supposed to know.
http://mcneel.myjetbrains.com/youtrack/issue/RH-32080
Hi Pascal,
when we import DWG’s printcolors might deviate from layer color.
So is there a way to script the following:
  • setting all layer colors to print colors
  • and then resetting the printcolors so they follow the layer colors automatically again?
Hi Jorgen - - right now, I do not see anything in RC for the latter - I’ll ask…
I did an if-not-same; set-same-color and that seems to fix it.
Scratch that…
I typed that after closing Rhino, so it does not reset it.
A way to link them back together with out having to right-click the layer-print-color icon and choose “Reset Print Color” would be great! Preferably as both a command and as a Rhino Common tool.
rs.LayerPrintColor(layer, None) would be a logic way to reset IMO
Cheers!
Yeah, I looked in the RC API to see if there was some function like that, but there isn’t yet. So once you set the print color of a layer to something else, you cannot change it back to “follow layer color” - the cutting of the relationship is irreversible. One workaround would be to create new layers, move the objects to that, then delete the old layers, but if you have a whole layer tree to manage, that’s pretty complicated and could potentially mess a lot of things up.
Yup, that would mess things up for blocks with content on different layers for sure…
So when needed I will have to go through the process of resetting it manually… :expressionless:
But I can live with a simple set-print-color-to-same-as-display-color script for now.
