Hi
I’ve been using these custom components to extract location information (which are awesome). Do you know why can I use Autodesk.Revit.DB.SiteLocation with a set parameter node searching for a ‘Latitude’ parameter? It is returning an error saying to parameter of name latitude for this element. This is the same logic if using Python in Dynamo so I’m confused. How can I define a new latitude and longitude?
I’m guessing these user components are still in development and will eventually be compiled to be apart of RIR. One suggestion when you compile - when outputting values it would be useful if the component did the conversion from radians to degrees as degrees is what Revit returns.
