I am trying to set the karamba display properties by C# in visual studio, however the field displayDisp of Karamba.Models.BasicDisplay is missing in KarambaCommon.2.2.0.142. While the online API of KarambaCommon 1.3.3 shows the property [BasicDisplay Class (karamba3d.com)]
Is there a other way to reach this property? See images for clarification.
Thanks, Max
I try to play around with the properties, however:
Karamba.Models.ModelResult.CollectElement1DCrossSectionForces(model, meshesKaramba, curvesKaramba) method returns no results.
Karamba.Models.ModelResult.CollectCroSecForceOutput_OLD(model, meshesKaramba, curvesKaramba) method returns straight lines, which does not correspond with the numerical results of the Karamba.Results.BeamForces.solve() method.
Am I missing something?
At the moment I have the following code:
public void DisplayModel(out List<Polyline> curves, out List<Mesh> meshes)
Model model = this.Model_0;
// Build and clone model
model.buildFEModel();
model.deepCloneFEModel();
model = model.Clone();
model.fe2model();
// Model properties
model.dp = (Karamba.Models.ModelDisplay)model.dp.Clone();
List<PolyLine3> curvesKaramba = new List<PolyLine3>();
List<IMesh> meshesKaramba = new List<IMesh>();
// Display properties Basic ??
Karamba.Models.BasicDisplay display = new Karamba.Models.BasicDisplay();
display.DisplayLoads = true;
display.DisplaySupports = true;
display.DisplayElementsID = true;
display.DisplayLocalAxes = true;
// Set display properties
model.dp.basic = display;
// Display properties for beams
Karamba.Models.BeamDisplay beamDisplay = new Karamba.Models.BeamDisplay();
beamDisplay.DisplayCrossSectionForceNumbers = true;
beamDisplay.displayCroSecForces = new bool[] { true, true, true, true, true, true };
beamDisplay.fillCSF = true; // make the cross section forces diagram filled
model.dp.beam = beamDisplay;
// Add meshes and curves of Forces [2] and [4]
Karamba.Models.ModelResult.CollectElement1DCrossSectionForces(model, meshesKaramba, curvesKaramba);
//Karamba.Models.ModelResult.CollectCroSecForceOutput_OLD(model, meshesKaramba, curvesKaramba); // Shows straight lines??
Rhino.RhinoApp.WriteLine("Curves: " + curvesKaramba.Count.ToString());
Rhino.RhinoApp.WriteLine("Meshes: " + meshesKaramba.Count.ToString());
List<Mesh> meshesOut = new List<Mesh>();
meshesKaramba.ForEach(t =>
Mesh mesh = new Mesh();
Rhino.RhinoApp.WriteLine("Vertices: " + t.Vertices.Count.ToString());
Rhino.RhinoApp.WriteLine("Faces: " + t.Faces.Count.ToString());
mesh.Vertices.AddVertices(t.Vertices.Select(v => new Point3d(v.X, v.Y, v.Z)));
for (int i = 0; i < t.Faces.Count; i++)
if (t.Faces[i].IsQuad)
mesh.Faces.AddFace(new MeshFace(t.Faces[i].A, t.Faces[i].B, t.Faces[i].C, t.Faces[i].D));
else
mesh.Faces.AddFace(new MeshFace(t.Faces[i].A, t.Faces[i].B, t.Faces[i].C));
meshesOut.Add(mesh);
curves = curvesKaramba.Select(t => new Polyline(t.Points.Select(p => new Point3d(p.X, p.Y, p.Z)))).ToList();
meshes = meshesOut;
Hi @maxhamelynck,
if “karamba.Models.BasicDisplay.DisplacementScale =! 0” then displacements will be plotted, otherwise not.
Thanks for the hint regarding the API documentation! I will update it in the coming days.
– Clemens
Did you calculate the model before retrieving results? I think the tests here could help you further.
– Clemens
