Our plug-in stopped working in the latest SR26 candidate because setting the Icon property of a dialog now throws the error below. This issue is new as of the latest SR candidates (that is, it does not occur in SR25). I should mention that we are building against SR18, but the same error occurs when building against SR25. Will we have to move up our references for SR26? This is of course doable, but highly undesirable, as most institutional users (large firms, universities, etc.) do not update Rhino frequently.
System.ObjectDisposedException: Cannot access a disposed object.
at System.Windows.Media.Imaging.BitmapSource.CriticalCopyPixels(Int32Rect sourceRect, IntPtr buffer, Int32 bufferSize, Int32 stride)
at System.Windows.Media.Imaging.BitmapSource.CriticalCopyPixels(Int32Rect sourceRect, Array pixels, Int32 stride, Int32 offset)
at System.Windows.Media.Imaging.BitmapSource.CopyPixels(Int32Rect sourceRect, Array pixels, Int32 stride, Int32 offset)
at System.Windows.Media.Imaging.BitmapSource.CopyPixels(Array pixels, Int32 stride, Int32 offset)
at MS.Internal.AppModel.IconHelper.CreateIconHandleFromBitmapFrame(BitmapFrame sourceBitmapFrame)
at MS.Internal.AppModel.IconHelper.CreateIconHandleFromImageSource(ImageSource image, Size size)
at MS.Internal.AppModel.IconHelper.GetIconHandlesFromImageSource(ImageSource image, IconHandle& largeIconHandle, IconHandle& smallIconHandle)
at System.Windows.Window.UpdateIcon()
at System.Windows.Window._OnIconChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.Window.set_Icon(ImageSource value)
at Eto.Wpf.Forms.WpfWindow`3.set_Icon(Icon value) in D:\BuildAgent\work\commercial\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\WpfWindow.cs:line 378
Thanks,
Jon
