Is there any way to change the default values of components? For example the partition list component drops on the canvas with multiple values of 3 and 2 in the size input and I would like this by default to just be 3.
Not really (atleast not with out some hacky scripting). Easiest way is to set the value you want, cluster the component, make it a user object so you can re use it.
If it’s just a single component, clustering shouldn’t be necessary.
True that, just habit.
