User created CPlanes are grayed out in the View-Set CPlanes menu. Can’t select one to make active via the menu. Seems to work fine in the Sidebar and the Named Construction Planes window. Happens with existing files and new files created in 510 on more than one Mac/type.
Yes, I checked this out and it is a bug. I will get it reported. In the mean time you can use the Named View Panel in the menu selection above. It will allow you to navigate the named views.
