Set Cplane to Object
would it be possible to improve Cplane - Object / Surface so that the function picks up the Cplane of the selected object automatically if an object is already selected when the command is executed? As it is now, it explicitly asks for an object / surface instead of using what the user has already selected.
Then it should just changes the cplane without interrupting whatever the user is doing so that the work can go on. Would save lot of time.
AutoAlignCplane is a good function, but not necessarily always good to have permanently on.
All the best
/Erik
Hi @erik6,
I believe the Rhino WIP’s CPlane > Object command/option already works this way.
– Dale
Hm,
I don’t think so. I select an object and run Cplane Object and it always asks for an object, never uses the one already picked …
/Erik
You need to pre-select a single object, not a polysrf.
Or sub select a single object.
Works in V8 and 9.
Ok,
but it is contra-intuitive. Objects (Polysrfs) have a Cplane associated with them as well. So it should work on Polysrfs. I mean, it works when you pick a box at the prompt. Why should it not work when you pick the box first and then run the command … ???
Hi @erik6,
Some polysurfaces have faces that are planar. For non-planar faces, we can cook up a plane from a selection point and a face normal.
When you run CPlane > Object and post-select a box, the command uses the pick location to determine the face. If you pre-select a box and run CPlane > Object, there is no automated way of knowing which of the 6 faces whose plane you want to use as a construction plane.
– Dale
Ok,
well I have not noticed that it picks the surface CPlane the user picks.
Now the million dollar question: What does “Object” then mean when you pick a Cplane Object ? If an Object is equal to Surface it seems redundant to have "Object " in the options for Cplane ?
Or? Is there some kind of Object that presents a Cplane and is not a surface of some sort?
I’ve written about this earlier as well.
Create a box. Click the box. Look at the gumball. It’s oriented in a specific direction.
Now rotate the box. Click the box. The gumball has rotated with the box’s rotation.
So now - why is the gumball rotated when the box is rotated? Well the gumball is oriented according to the box. It’s not oriented to the surfaces, because you can pick the box anywhere and it does not change the gumball orientation Rhino presents.
Therefore, I can conclude that the box is an object.
So if I click on a box and then invoke Cplane Object, why does it not understand the box object’s cplane ?
I don’t understand.
Thanks
/Erik
Sure,
let me rephrase it: what does the gumball represent when you pick a box? It’s not the same thing as Cplane Object I now understand (because the Cplane object represents one of the surfaces of a box).
To me this is a bit confusing.
/Erik
