Set constrain for bending of polyline (bending-active rod / steel-cable)
Hi there,
I am working on a bending active prototype with a mesh in between. I found an old example from Anders Deleuran about his workshop back in 2016 at the RDA.. I want to bend a polyline while being constrained by a tensioned steel cable in-between that.
So far I get it, how to use the Rod component, but when it comes to setting a constrain on the amount of bending till the energy is at its minimum and the solver found an equilibrium, I am a little stuck.
As the screenshot shows I am having my rectangular shape on the left with the linear cable in between. But when it converges it just forms a circle and ignores my Anchor points, the ConstantTension node. I also tried out the PointOnCurve, and others more but I cant wrap my head around that.
What is stopping my simple geometry from obeying the anchor points, stiffness and tension forces of my line?
Many thanks in advance for any idea about that!
Or is it easier to solve with K2?
Please share your files.
