Serializing hatches (C#)
Hi there,
I am trying to serialize hatches in order to use them as a resource in Visual Studio.
It works fine for simple hatches, but as soon as I go a bit more complicated (more than 5 corners), I get an exception.
Code snippet:
using (MemoryStream stream = new MemoryStream())
            BinaryFormatter formatter = new BinaryFormatter();
            formatter.Serialize(stream, some_hatch);
            stream.Position = 0;
            return (Hatch)formatter.Deserialize(stream);
It throws this exception on the serialize-line:
A first chance exception of type ‘System.ArgumentNullException’ occurred in RhinoCommon.dll
Additional information: Value cannot be null.
If there is a handler for this exception, the program may be safely continued.
Any ideas?
All the best,
Gustav Good
Just to clarify, are you trying to serialize a Rhino.Geometry.HatchObject or a Rhino.DocObject.HatchPattern?
Rhino.Geometry.Hatch that is.
This seems to work:
  var pattern_index = doc.HatchPatterns.CurrentHatchPatternIndex;
  if (pattern_index < 0)
    RhinoApp.WriteLine("No hatch patterns found in the document.");
    return Result.Nothing;
  var circle = new Circle(Plane.WorldXY, 5.0);
  var arc_curve = new ArcCurve(circle);
  var hatch = Rhino.Geometry.Hatch.Create(arc_curve, pattern_index, 0.0, 1.0);
  if (null != hatch && hatch.Length > 0)
    using (var stream = new MemoryStream())
      var formatter = new BinaryFormatter();
      formatter.Serialize(stream, hatch[0]);
      var some_hatch = formatter.Deserialize(stream) as Hatch;
      if (null != some_hatch && some_hatch.IsValid)
        doc.Objects.AddHatch(some_hatch);
        doc.Views.Redraw();
  return Result.Success;
Let me know if you find otherwise.
– Dale
Dale,
Thank you for a quick reply.
Here is a link to a hatch that fails with this approach:
https://drive.google.com/file/d/0B6ntVYN1MZ8QRzNnem80M1V5akk/view?usp=sharing
All the best,
Gustav
Hi Gustav,
If I run this code:
  var go = new GetObject();
  go.SetCommandPrompt("Select hatch");
  go.GeometryFilter = ObjectType.Hatch;
  go.Get();
  if (go.CommandResult() != Result.Success)
    return go.CommandResult();
  var hatch = go.Object(0).Hatch();
  if (null == hatch)
    return Result.Failure;
    formatter.Serialize(stream, hatch);
      doc.Views.Redraw();
and pick the hatch in your model, I end up with two identical hatch objects.
What am I missing?
Resolved by updating Rhino from SR8 to SR11.
Thank you
