Serialize ArchivableDictionary to ASCII
I am using ArchivableDictionaries saved as Rhino User Data for my plug-in. Everything works fine. However, I’d like to implement import and export of my plug-in data to ASCII format for data exchange with other softwares. My idea is to implement a conversion from ArchivableDictionary to JSON. However may be something is already existing. Does anybody know of conversion of ArchivableDictionary to some ASCII format and back?
regards,
Samuel
Hi @samuel.hartmann,
I believe this is on the to-do list.
https://mcneel.myjetbrains.com/youtrack/issue/RH-65082
– Dale
Hi Dale,
Thanks for the answer.
As far as I understand it, if ArchivableDictionary supports serialization, it could be serialized with any JSON serializer. So that would do the job.
But at the moment, this is not the case yet.
Samuel
