I’m trying to serialize and deserialize a mesh to a file,
the first part is working, however, the deserialization is through an error.
what should I do to fix it?
Still haven’t tested this but I believe you should use pickle
I tried with pickle, and it didn’t work with meshes as well.
it’s very strange that CommonObjectToByteArray worked well, however, ByteArrayToCommonObject gives this error:
“1. Solution exception:The type arguments for method ‘ByteArrayToCommonObject’ cannot be inferred from the usage. Try specifying the type arguments explicitly.”
