Is it possible to have a seperate maximum and minimum for each gene pool in grasshopper for galapagos
Yes, each gene pool had its own min/max settings. All the individual genes inside that pool then inherit that domain.
If you want individual domains per slider, then you’ll either have to create separate sliders, or post process the values from a gene pool. Basically set your domain from zero to one, then multiply the values coming out of your pool with an equally long list of scaling factors.
