Hi Forum,
I’m requesting some insight on how to tackle the the following: I have a generated list which I would like to:
separated based on the values: Val A and Val B
retain the list position of Val A and B as null in new lists
have the ability to modify Val B
reconstitute source list with updated Val B
Attached is a sketch of where my head is at together with the source list
thanks in advance
list_query.gh (18.1 KB)
inno
August 19, 2022, 3:23pm
2
Sift Pattern + Combine Data do exactly what you are looking for
list_query_Re.gh (10.6 KB)
Hi Inno,
Would you be so kind as to knock up a quick definition as to how - I’m sure it’s as simple as you describe, I’m just not seeing the wood for the trees at this portion of the day.
Lina
(LinaV)
August 19, 2022, 3:28pm
4
hi, @ryan.paetzold
You can use the components Sift Pattern
with Combine Data
list_query_edit.gh (12.8 KB)
You can find more useful information about data filtering with Sift Pattern in the tutorial below.
Thanks @Lina
Thanks for both solution and link to tutorial - much appreciated
@Inno - sorted thanks
