Sending downloaded models onto iPad
Is there anyway I can send downloaded models from turbosquid onto my iPad? Whenever I try to download directly on my iPad then open it on Rhino I always get the same message about it not supporting this file type. Could really use help with figuring this out if possible.
Hi @Max_Schmidt
What file format are you trying to import? And are you using the Open or the Import command?
HTH, Jakob
If you’re trying this with a 3dm file you can just open directly from your browser’s downloaded files into iRhino
Alternatively you can save to your files and open from there.
