Sending curved surface strip to Revit as Equal Divided Panels
Hello, I was inquiring if there is a way to send this Strip made of polysurface to Revit, as a native Revit element. Moreover, send them as equal-spaced panels without losing resolution with adaptive components. Attached is the sample isolated internalized geometry of the strip. Thanks in advance!
P.S At the moment I could only manage to send by utilizing the surface segment points to split it which of course gives irregular-sized panels and a lot to compute!
Strip-RH8.gh (43.9 KB)
Hi A.Lee,
You’ll get quicker and more thorough responses if you post this to the Grasshopper forum category with your spacing requirements.
An Adaptive component might be the best solution, where are you losing resolution in the process?
