Like all AutoCAD veterans, I am used to type P for previous selection set. It is easy to make this keyboard shortcut in Rhino, but its default P keyboard shortcut launches Planar command. Planar command shortcut is already hard-wired into Rhino status bar, so duplicating it in the keyboard shortcut is superfluous. Having keyboard shortcut for previous selection set is much more important.
I suggest that default P keyboard shortcut launches SelPrev command rather than Planar command.
Excellent point for āAutoCAD veteransā, but by now there are a whole bunch of āRhino veteransā. How many of these already have trained themselves to use P for Planar and would be completely put off by your change to the default and would need to use the āeasy keyboard shortcut changeā to put it back to what they are used to?
Rhino is not AutoCAD and I think this is the kind of thing that could have been designed in at the beginning to make it easy for AutoCAD users but wasnāt, so I guess itās just one of the differences that must be adapted to. At least veterans of any other CAD system can use the shortcut definition facility to set Rhino up to be as close as possible to what they like.
The essence of your argument is that mental inertia is good and nothing should ever be changed. The essence of my argument is that we need very fast access to the SelPrev command.
I would have a slight disagreement with you there.
More to AIWās point, your suggestion would change the default to one that some AutoCAD users are familiar with. I suspect most Rhino users would not see that as an improvement.
Since itās trivial to change in Rhino for the AutoCAD users that itās important for, I think weāre there.
As for me Iām fine with setting up the aliases that suits my way of doing things. I think Iām with @John_Brock on this one. And essentially with you, too, based on your own argument about what users have gotten used to. Your argument is strong on that one. In favor of Rhino users as well as Autocad users.
Never use SelPrev, havenāt since like V2 when it got broken - maybe itās āfixedā now, but as Iāve never found it useful, Iām not going to be advocating any kind of change here.
In any case people are free to create the aliases they want and I personally donāt feel that AutoCAD similarity is an important criteriaā¦
For me, that transition from AutoCAD to Rhino was quite a while ago (somewhere near the release of V2), so I might not be the best one to ask. I will say thought that I certainly remember some speed bumps my transition, the biggest for me that I recall was transitioning from middle mouse button press and drag for pan to right mouse button drag, that took me a while
I think though that the argument that Rhino isnāt AutoCAD does carry weight however. There is a large segment of people who either didnāt come from AutoCAD or have learned and have gotten used to āPā for planar for whom this would be a confusing change, or who are still learning and āPā might not logically correlate to selPrev (or selLast). In my case, Iām glad I found Planar because now I toggle it almost as much as OSnaps (it is now F4, right next to OSnaps at F3). It is just a preference of tool use frequency, and were they should be placed.
This doesnāt mean that transitioning people from one platform to another couldnāt be made easier. In your case, I imagine it would have been nice if it were more discoverable to you that you could change aliases and keyboard shortcuts to better mimic a program you already know. I wouldnāt at all be opposed to some sort of AutoCADPrefs.ini, which would just be an OptionsExport which mimics as many of AutoCADās default preferences as possible. As I have said before, I havenāt worked in AutoCAD in so long, Iām not sure I could do a good job of this though.
I sometimes wonder if it would help if in the help docs if there was a header for each topic with a link that read something like āCanāt find what you are looking for, or still confused? Ask the community at discouse.mcneel.comā so workarounds like this could be found in a more expedited manner.
Iām an old AutoCAD user and this doesnāt bother me at all. I have āPā set to āpolylineā in both Rhino and AC SelPrevious is also useful - I have āSPā for thatā¦
