SelLast in macro not working
Either I’m having a brain fart here, or something is not working…
Create a simple plane surface, anything will do… then run the following macro from the macro editor:
! _ExtrudeSrf _Pause
_BothSides=_No
_Solid=_Yes
_DeleteInput=_No
_SelLast
The created solid doesn’t select… I see “SelLast selection set is empty.”
However if you then run just SelLast (use the button or type the command), the newly created object lights up…
I’m confused…
–Mitch
Never mind, just left out a pause…
