SelID for multiple objects
I am trying to implement in C# a command that performs selection like SelID, but for multiple objects. It works fine when I run it like this: _MyCommand guid1,guid2 But it doesn’t work when I run it inside another command, for example: _-Join _MyCommand guid1,guid2 _EnterEnd. I am using [CommandStyle(Style.Transparent)] and doc.Objects.Select(idsList). Any suggestions?
Hi @Fernando_Fonseca_Aco,
The Join command only allows for a single object selection when post picking. This is why you see the “Cannot use these objects. Removing them from selection.” message.
Something like this, which pre-selects, probably works:
_MyCommand guid1 guid2 _Enter _Join
– Dale
Thanks @dale
You are right.
The Join command have 2 selection times.
Then:
_Join _MyCommand guid1 _MyCommand guid1 _Enter
works too.
