Selection within a command
I am looking to make a selection during a command by using a script (python ideally). For example, suppose i run a command that takes a point as input. how do i script the selection of the point, and allow the command to continue?
I tried a naive approach of making a document with one point in it, running the command, and then typing SELPT, but this didn’t work.
rs.GetPoint()
will allow you to click a point.
http://developer.rhino3d.com/api/RhinoScriptSyntax/win/#userinterface-GetPoint
rs.GetObject()
may be used to select a pre-existing point in a document.
http://developer.rhino3d.com/api/RhinoScriptSyntax/win/#selection-GetObject
(there are some other ways as well)
