Selection Window Stroke Logic · Wish
should the strokes not be the other way around, meaning the window crossing be actually a solid (unforgiving) line and the normal window selection dashed? or is there a way to customise it? if not could it be implemented?
Well, I guess the ‘logic’ could be looked at either way - i.e. a hard ‘unforgiving’ line as you put it tells you the selection has to remain strictly inside it (Window). Ye shall not cross that line…
This is probably hard coded into Rhino, doubt it’s customizable.
yes, that sure was the initial idea. but now having the options to customise stroke and fill color, it occured to me that other way around seems rather more straight forward, without having to think around the corner. anyway since everything else is customisable, i think it would be a neat enhancement having this option also.
