Selection report sorted by type
I sometimes check/compare the content of 2 selection sets.
What I do is window select an area and than another area to compare and see if the object count is similar.
However, it can be tedious when various types of objects are selected since the order in which type-count is reported is arbitrary.
For example below are 2 sets window selected one is a copy of the other:
29 extrusions, 10 polysurfaces, 44 curves added to selection.
44 curves, 10 polysurfaces, 29 extrusions added to selection.
If the report could be sorted such that object-types are in alphabetical order, it’s much easier comparing the 2 sets.
-Willem
Hi Willem - thanks, added to the mountain:
https://mcneel.myjetbrains.com/youtrack/issue/RH-36004
