Selection filters not working
In the last version of R9 selection filters are much improved graphically, but they seem not to work.
See video. I can’t click and get several categories at the same time.
selection filters not working
Only the right mouse button works and it select only one category.
Also the buttons flicker when you hoover over them.
Also I strongly disagree about the “Disable” button. It needs to be clearer. As it is now the user reacts to the “red symbol” and reads it as if the selection-filter is already disabled. It would be clearer if it said “Disable” and then when clicked the whole palette would turn greyed out (and a red symbol would appear) while the button changes to “Enable”.
Also the bluish colour field behind the buttom could be reinforced, made more graphically strong. Maybe add shadow when button is “depressed”. The checkboxes were clearer but graphically poor.
But please please fix the functionality ASAP. It becomes a bit to work with the R9 when they are not working.
Thanks
/Erik
Rhino 9 SR0 2026-6-23 (Rhino 9 BETA, 9.0.26174.12303, Git hash:master @ 8cd1747b0e2a5abafffff683b0f00f4bbe7bf2a9)
License type: Commercial, build 2026-06-23
License details: Cloud Zoo
Expires on: 2026-08-07
Strange.. if you switch modes. EG Run TestOsnapToggles and Turn off the UseToggles option so that it goes back to checkboxes does that solve the issue? Trying to determine if the buttons are broken for you or the filters are.
exactly the same behaviour with the old checkboxes. I can only check the boxes with the right mouse button. I actually need to vehemently click the right button to get the checkbox clicked. One click is not enough, I need like 15 clicks …
/Erik
if you dock the panel does the problem stop?
RH-96538 OSnap/SelectionFilter buttons un-clickable at times.
RH-96538 is fixed in Rhino BETA
